CUC 8.5.(1) with Exchange 2010 TTS issue
michelegarribba
I'm configuring CUC 8.5(1) ( 2 servers in HA ) with MS Exchange 2010 ( one server in a MS domain ).
Single inbox works well, so voice recognition.
I'm now trying TTS but i'm encountering some problems.
Feature is licensed, so i enabled it in the class of service and flagged the allow user to access voice mail
using imap client and\or single inbox. Also at user level the proper configuration is done.
I followed the official guides about it and all recall to a 8.0 with exchange 2007 way to enable imap access
using external services and external services accounts.
My issue is that i don't have these voices in my system settings of my CUC.
Where should i point my attention to get it work? The environment is only internal so exchange is not configured
for TSL, is it mandatory to have it enabled? How should i access emails in TTS mode by phone? I tried the
voice mail interface but it doesn't speak about emails, only voicemail.
Is there any step by step guide correct\update for exchange 2010?
Thanks to all for your help, i'm at a stuck and i need this feature working in a few days.
Michele
In the Classic Conversation phone menu, it announces option 7 by default.  "To play external messages"
5 Replies 5
Bradford Magnani
Hi Michele,
It should be button-press 7 to play external messages.
Hope that helps,
Brad
Thanks Brad, i'll try it.
Should i have announcements that i have emails to be read from the phone voice menu when i get in? 'Cause i have
for voicemails but not for emails, and i flagged the option in the phone menu of the user profile.
Michele
Do you think my settings are correct? Thanks Brad i'll for sure let you know if it works
Thanks a lot Brad,
All is working, just a couple of question, i'm also using voice recognition, it works but it doens't has the
play external messages option, is there any specific i have to set or say?
The touchtone command in my classic conversation is not 7 but i have to execute a little procedure following the
menu, somenthing like 0 --> 9 --> 1 ---> 7 ( external message option ) --> 1
Is there any way to change or abbreviate this ?
Thanks again
Michele
