CUC 8.6.2 upgrade
hzarringhalam
I am going to upgrade CUC 7.1.3 and CUCM 7.1.5 to 10.0.
How can I get the bootable install file for CUC  8.6.2 and is CUC 8.6.2 compatible with CUCM 7.1.5.
Regarding CUC, my plan is to upgrade CUC to 8.6.2 on MCS. It means that I will have CUCM 7.1.5 and CUC 8.6.2.
Then I will do a fresh install of CUC 8.6.2 on VM and restore 8.6.2 from MCS to VM and upgrade it CUC to 10.
I placed CUC upgrade order through PUT and got the upgrade file but not the install file for CUC 8.6.2. I need bootable install file for my fresh install on VM.
Please let mw know if you have a heads up for me about this upgrade ....I did not mention that I am going to upgrade CUCM 7.1.5 to 10 through PCD (Prime Collaboration Deployment).
Thank you,
Hamid
15 Replies 15
Hello Aman,
I will do. Thanks for your great idea.
Hamid
