CUC - Call Routing Rule set as Inactive by Default
Alhaia170
How to set to '' Inactive '' the default status of a new Call Routing Rule in CUC 8.6+ !?
When creating a new Dial/Forward Routing Rule, I want the status to be set by Default to '' Inactive ''...  The default choice is Active.
Jaime Valencia
https://supportforums.cisco.com/discussion/12200541/cuc-call-routing-rule-set-inactive-default-status
java
if this helps, please rate
