CUC - CUCM AXL Integration Issue
Jagsuvce G
Our Unity Connection version10.5 and CUCM version is 8.6. Currently am trying to integrate CUC with CUCM through AXL, i have done all the setting appropriately. Also test to CUCM server is successful.
But while importing am seeing the error -- "Error encountered. Check the Application Server Settings on CUCM for CUC".
Also CUCM i have given the username and password without any special characters in it.
Pls suggest, where could be the issue.
2 Accepted Solutions
Hi Jagadish,
this bug could be the issue
CUC 10.5 cannot import users via AXL
CSCup78196
Symptom:While import user into CUC, using AXL integration with CUCM version prior to 9.x
import user fails with following error
"Error encountered. Check the Application Server Settings on CUCM for CUC."
Conditions:CUC 10.5
CUCM pre 9.0
AXL integration
Workaround:Import users via LDAP
or Upgrade CUCM to version 9.x or later
More Info:
you are welcome.
regds,
aman
6 Replies 6
Aman Soi
Hi Jagadish,
how long is the password?
can u try using password say for 5-6 characters and then,check?
regds,
aman
Dear Aman,
Changed the password to 5 characters, but no luck.
Pls suggest.
Hi Jagadish,
can u have a look in to this atatched DOC even though versions are different.?
regds,
aman
Hi Jagadish,
CSCup78196
Conditions:CUC 10.5
CUCM pre 9.0
AXL integration
More Info:
Jagsuvce G
Thanks Aman, I tried searching but I couldn't get this bug over google. Thanks for the update.
you are welcome.
regds,
aman
