CUC extension capacity users 5000 >> 10000
tdudas
Hi All,
Am I correct that to extend Unity Connection capacity from 5000 users to 10000 user the only way is to create a new Virtual Machine with the template of 10000 users. Do backup on the old servers (HA setup) and restore configuration on the new VM? Should a license file to be asked from licensing team because of the new setup?
Tibor
Jaime Valencia
Correct, you would need to DRS into a 10K VM.
Licensing will depend on your version and where the licenses are hosted.
java
if this helps, please rate
