When using IF statements, labels are not needed against them all and if you want them to flow down in order don't populate the false section.
If you can I would recommend replacing IF cases with the switch tool, you can use the dialed/called number to make a connection to each language based upon matching the number. You can then set the prompts and group number for redirect. Makes it easy if need to add more later as well.
Note the picture is a little rough but hopefully you get the idea.
Please rate helpful posts
