cucm 10 licencing
ajay1komban
Dear all,
                      Can I change cucm10x  IP address installed on ucs server(vmware platform).
                     If I change ip address, is it effect licence ?.
Ajay Jose K
No, 9.x and 10.x use the same licensing method and on neither of them there is a license MAC anymore.
Licenses are tied to ELM and PLM respectively, and each has a unique hash which is used to license the UC apps to the licensing server. Changing IP of servers managed by PLM/ELM no longer has anything to with rehosting licenses. You just would need to re-configure ELM/PLM to look at the new IP (if configured using IP)
Anything before 9.x on Linux appliance, still has a license MAC
java
if this helps, please rate
Emmanuel Valdez
Level 3
Level 3
From version 8.6 to 9.x you had to send a license rehost request to Cisco Licensing team, in version 10.x doesn´t exist MAC License so maybe you can change the IP Address without need rehost licensig, do you have experience doing it?
Regards.
java
Dear all,
Thank you for your Reply.
Ajay Jose K
