CUCM 8.5 / SIP Load Test / Getting 403 Errors
Steve Earl
I have a SIPP based load test client setup and working over a SIP trunk to my test app server.  It's a fairly basic SIPP scenario (INVITE, ACK, Play PCAP, BYE).  I can run the load test client for a period of time generating 100 simultaneous calls.  At around 400 calls I start receiving SIP 403s upon the INVITEs.  The Reason SIP header value is: Q.850;cause=21.
I can keep sending calls and some of them process without issue, however after around 400 calls I end up getting 403s on approximately ten percent of the calls.
Below is a snippet of logging indicating the error.
12:57:58.936 |StationD:    (0000796) SetRinger ringMode=1(RingOff).|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |StationD(796): StationCtiD - StationOutputSetRinger|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |deleteCi: Unable to find the device that owns the call with CI=28612389|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |LineControl(868) - Release call instance=2 for CI=28612389|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |LineControl::sendSNFNotifyIndForPresenceWithAlerting mPrecenceWithAlertingChangeNotifySubscribed=0, calllist#=25|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |LineControl (868) - DStopInd - Last one is still received|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |LineControl(868) - 25 calls, 0 CiReq, busyTrigger=10000, maxCall=10000|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |processCCMFeatureData: operationIeIdd=0|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |ConnectionManager - wait_AuDisconnectRequest ERROR:NO ENTRY FOUND IN TABLE,CI(28612388,28612389),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|1,200,17,1.444887^10.20.17.30^2000
12:57:58.936 |Cdcc - (0065765) - resetMediaSecurity|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPD(1,67,10)/ccbId=0/scbId=0/getKeyBasedOnCiAndBranch: AddressingElement branch is 0 and ci is 28612388  mapKey is 28612388|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPD(1,67,10)/ccbId=0/scbId=0/getCdpcPid: found Cdpc Pid (1,100,68,34273) for mapKey 28612388|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0x0/sipConstructContainerContext #### Created container=0xb1eedd70|1,100,65,1.1^*^*
12:57:58.937 |//SIP/SIPCdpc(1,68,34273)/ci=28612388/ccbId=530215/scbId=0/appendReasonHdr: appendReasonHdr - Invalid Disconnect Cause(cause=21), No Reason Header Appended|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPCdpc(1,68,34273)/ci=28612388/ccbId=530215/scbId=0/addTransparencyInfo: Transparency info is NULL.  Not attaching anything.|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0x0/ccsip_spi_get_msg_type returned: 3 for event 8|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0xaa2e8708/Performing disconnect|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_EXPIRES value=1800000 retries=0|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0xaa2e8708/****Adding to UAS Response table.|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0xaa2e8708/Added to table. ccb=0xaa2e8708 key=236-23780@10.20.17.64530215~37C71E3A-0C2F-4A3E-AC5C-9390087ABFE3-28612388|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0xaa2e8708/Associated container=0xb1eedd70 to Invite Response 403|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Transport/0xaa2e8708/msg=0xa9e481e8, addr=10.20.17.64, port=56298, sentBy_port=56298, is_req=0, transport=1, switch=0, callBack=|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Transport/0xaa2e8708/Proceedable for sending msg immediately|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Transport/0xaa2e8708/switch transport is 0|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Transport/0x0/Posting send for msg=0xa9e481e8, addr=10.20.17.64, port=56298, connId=0 for UDP|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/Info/0xaa2e8708/Sent an 3456XX Error Response|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/Stack/States/0xaa2e8708/0xaa2e8708 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_CONNECT value=500 retries=6|1,200,17,1.444887^10.20.17.30^2000
12:57:58.937 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: type=SIP_TIMER_CONNECT value=500 retries=6|1,200,17,1.444887^10.20.17.30^2000
12:57:58.939 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.20.17.64:[56298]:
[7046533,NET]
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.20.17.64:56298;branch=z9hG4bK-23780-236-0
To: <sip:2000@10.20.17.40:5060>;tag=530215~37c71e3a-0c2f-4a3e-ac5c-9390087abfe3-28612388
Date: Tue, 29 Jan 2013 17:57:56 GMT
Call-ID: 236-23780@10.20.17.64
CSeq: 1 INVITE
Allow-Events: presence
Reason: Q.850;cause=21
Content-Length: 0
Any thoughts on what would cause a relatively limited number of calls to run through successfully and suddenly start getting 403s?
colan.haisell
Hi Steve,
I would like to use SIPP for some performance testing on CUCM. Could you please share your CUCM and SIPP config for this particular test you have described?
Thanks in advance,
Col
