cucm 8.6 to 10.5 and cisco phone 7911
Alain Comtois
WE will upgrade to cucm 8.6 to 10.5.
We have a lot of sccp 7911 phone.
Can we use this phone with 10.5 ?
Will we find the software for this phone in the 10.5 devicepack ?
If not can i install cmterm-7911_7906-sccp.9-4-2-1.cop.sgn to cucm 10.5
Tanks
Jaime Valencia
Yes, we have not removed any phones from the drop down
If you want to know what FW is included in a DevPack, read the DevPack documentation.
Same for device FW, if you review the info on downloads (see below), or FW documentation, you'll find compatibility
7911/7906 SCCP IP Phone load - Compatible CUCM Versions: 5.0.4, 5.1.3, 6.0.1, 6.1.3, 6.1.4, 7.0.2, 7.1.2 and above
java
if this helps, please rate
adawa
Level 3
Level 3
Hello, sabbaticz.
Jaime is correct, check this link to verify compatibility: (http://cs.co/9004qG7Q). Are you already working with you local Cisco partner or representative for this migration?
Let me know if you have other concerns or e-mail (adawa@cisco.com) me directly.
