07-08-2014 11:56 PM
Hi all,
Has anyone tried to upgrade to IM&P 10.5(1) server with a 10.5(1) deployment of UCM? The versions are different, CUCM 10.5(1) is 10.5.1.10000-7 and IM&P 10.5(1) is 10.5.1.10000-9
When I try to run the update I receive an error message saying the deployments do not match.
Anyone else had this problem?
Karl
07-09-2014 10:22 AM
Karl,
I recommend you also post this to the Cisco Support Community for additional information and feedback.
Hope that helps,
Kelli Glass
Moderator for the Cisco Collaboration Community
07-25-2014 10:51 AM
Hi Karl,
Ran into the same issue. The upgrade went through after I installed the following cop file ciscocm.version3-keys.cop.sgn
Gary
