CUCM Call Flow
winston75
What is the best way to view all call flows i.e (RP, RL, RG)
the purpose of this is i have inherited a system that has been upgraded over the years form CUCM 4 and now we are on 11.5 and it has tons of old configurations in the call flow. I am trying to determine what needs to be removed.
Any assistance would be greatly appreciated.
williams.mark.m
I don't think you will like this answer, and there may be better ones out there, but show dependencies is your friend in this situation.  Unfortunately it does mean that you need to click through each item in question, show dependencies, see where they are linked to and follow the trail backwards to see if those items are in use.  It is a cumbersome process, but also the only one I am aware of outside of using a third-party tool.
i appreciate that. Any info will be helpful. i will give it a shot thanks.
DNA can provide some information if you can't find a specific call flow, but as mentioned, it's mostly spending time reviewing the configuration and then connecting the dots between the different elements.
java
if this helps, please rate
the individual call i can find. I am looking for a search that can show me multiple calls that shows route pattern used.
