CUCM CLI OS ADMIN LOGIN ISSUE
nabeel asghar
I am facing an issue for login in CUCM OS Admin on CLI, while logging in as I am giving the username and password, it shutdown the putty, I tried through console as well, after giving the username and password, it's again showing the login page asking username and password.
Please advise for the same as I need to troubleshoot replication issue.
Regards:
Nabeel
7 Replies 7
Aman Soi
Hi Nabeel,
could be an issue with privilege level of OS username?
are u able to login through GUI using same OS credentials
Hello Aman,
Thanks for your response
Yes I am able to login through GUI using OS credentials.
Also I am able to login cucm sub node in CLI using os credentials
Hi ,
What is CUCM version?
I was just going through the bug .
OS admin login works with Subscriber. Does not work with Publisher
CSCuz84221
Description
Symptom:
Unable to login to CUCM Publisher OS Administration (GUI or CLI)
Conditions:
Unknown
Workaround:
Login via CUCM Subscriber OS Administration
(1)
11.5(0.99838.5)
Known Fixed Releases:
(2)
Known Affected Releases:
(1)
11.5(0.99838.5)
(2)
11.5(1.10000.5)
11.5(2.10000.4)
Here is the exact version of CUCM we have installed
System version: 9.1.2.10000-28
could you please advise  how can I resolve the same
Do u have any other applications like UCCX/Unity installed in setup ? If yes, are u able to login through same putty  ?
regds,
aman
Yes we have the unity connection with same version and I am able to login it's OS Admin credentials through putty and through console as well.
Moreover in cucm subscriber nodes also I am able to login using OS Admin credentials.
hi,
can u share the output of command
show myself
and show account from subscriber
