06-11-2018 10:10 AM - edited 03-19-2019 01:24 PM
Hi There
I was looking what´s need to be done in CUCM for being monitor it, I would like to monitor
- CUCM whole cluster
- CUCM database Replications
-is there any way to monitor the MTP, MOH
- Any phone unregister.
I know this can be done in RTMT tool, but the monitoring team will not use it, so what should I tell the monitoring team to monitor my CUCM and the things I said before? thanks.
06-11-2018 10:23 AM
06-11-2018 12:07 PM
Thanks very much
but they will be using "Manage engine OpManager" basically we are looking if any specific configuration in CUCM, maybe with SNMP, or what should I provide them,
thanks.
06-15-2018 11:36 PM
Hello Israel,
If you are using a Third party NMS , then you will need to configure it via SNMP.
Hope that helps.
