CUCM , CUBE and router compatibility
foued kh
HI all,
I need please a document which illustrate the compatibility between CUCM, CUBE and router where we install the cube ios image
Thank you in advance
Jitender Bhandari
Below is what you are looking for .
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
(Rate if it helps)
JB
Jitender Bhandari
(Rate if it helps)
JB
