CUCM DID number is not directing to Extension
TM13
  I added additional DID number on our current CUCM, but it is not directing to the extension, it is directing to the current number auto answer, any idea?
Voice Gateway config:
dial-peer voice 1 pots
service aa
incoming called-number 99112233
dial-peer voice 2 pots
incoming called-number 99112234
direct-inward-dial
Translation Pattern on CUCM
Translation Pattern - 99112234
Called Party Transform Mask - 2234
Calling Party Transform Mask - 2234
Extension 2234 is our group number,
Any additional config needs?
Hi Tulga,
1>     Create a Translation Rule from 5 digits to 4 digits.
2>     Remove Prefix Digits currently set on PRI config page and change significant digits from 0 to 5. Save, Apply and Reset.
Let us know how it goes.
HTH.
Harmit.
10 Replies 10
Jaime Valencia
Where's the DP that points to CUCM??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Yes to CUCM,
Harmit Singh
Hi Tulgabat,
Can you post the entire gateway config please? Assuming you are using a PRI for PSTN access, kindly configure the following debugs and attach them along with the config:
debug isdn q931
debug voip ccapi inout
Please mention the calling and called party numbers.
Harmit.
Feb 21 05:22:00.481: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x18F9
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18398
                Preferred, Channel 24
        Calling Party Number i = 0x2183, '***'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '99112234'
                Plan:ISDN, Type:Subscriber(local)
Feb 21 05:22:00.533: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x98F9
        Channel ID i = 0xA98398
                Exclusive, Channel 24
Feb 21 05:22:00.533: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x98F9
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Feb 21 05:22:00.533: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x98F9
Feb 21 05:22:00.587: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x18F9
Feb 21 05:28:10.648:  vsacount in free is 22
Feb 21 05:28:10.670: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x332F
Feb 21 05:28:10.782: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1AC3
Feb 21 05:28:11.154: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1AC7
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA1839D
                Preferred, Channel 29
        Calling Party Number i = 0x2183, '*****'
Feb 21 05:28:11.180: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22F3AFB4, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000002b9c354000000F580001ac7)
Feb 21 05:28:11.180: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 21 05:28:11.180: :cc_get_feature_vsa malloc success
Feb 21 05:28:11.180:  cc_get_feature_vsa count is 23
Feb 21 05:28:11.180: :FEATURE_VSA attributes are: feature_name:0,feature_time:737277656,feature_id:1251820
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccCallSetContext:
   Context=0x237144F8
   Interface=0x224908D0, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Feb 21 05:28:11.180:  cc_get_feature_vsa count is 24
Feb 21 05:28:11.180: :FEATURE_VSA attributes are: feature_name:0,feature_time:737293784,feature_id:1251821
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/ccCallSetContext:
   Context=0x23711B08
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/cc_api_call_connected:
   Interface=0x224908D0, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_call_proceeding:
   Interface=0x22F3AFB4, Progress Indication=NULL(0)
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_call_connected:
   Interface=0x22F3AFB4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x234D1598, Call Id=1251894
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccCallReportDigits:
   (callID=0x131A36, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=1251894
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x22F3AFB4, callID=0x131A36, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x22F3AFB4, Call Id=1251894
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccConferenceCreate:
   (confID=0x234D17AC, callID1=0x131A36, gcid=0-0-0-0, tag=0x0)
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/ccConferenceCreate:
   (confID=0x234D17AC, callID2=0x131A37, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x234D17AC, Call Id1=1251894, Call Id2=1251895, Tag=0x0
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_bridge_done:
   Conference Id=0x98B99, Source Interface=0x22F3AFB4, Source Call Id=1251894,
   Destination Call Id=1251895, Disposition=0x0, Tag=0xFFFFFFFF
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/cc_api_bridge_done:
   Conference Id=0x98B99, Source Interface=0x224908D0, Source Call Id=1251895,
   Destination Call Id=1251894, Disposition=0x0, Tag=0x0
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x98B99, Destination Call Id=1251895)
   Call Entry(Conference Id=0x98B99, Destination Call Id=1251894)
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x224908D0, Destination Call Id=1251895, Source Call Id=1251894,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22F3AFB4, Destination Call Id=1251894, Source Call Id=1251895,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Feb 21 05:28:11.180: //1251895/50F19F848B5A/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7793)
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_caps_ack:
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x22F3AFB4, Call Id=1251894
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_api_voice_mode_event:
   Call Id=1251894
   Call Entry(Context=0x237144F8)
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x98B99, Call Id1=1251894, Call Id2=1251895
Feb 21 05:28:11.180: //1251894/50F19F848B5A/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Feb 21 05:28:11.180: //1251894/50F19 no F848B5A/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=1251894
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Feb 21 05:28:11.196: //1251894/50F19F848B5A/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x234D14B0, Call Id=1251894
Feb 21 05:28:11.196: //1251894/50F19F848B5A/CCAPI/cc_api_call_modify_done:
Feb 21 05:28:11.196: //1251894/50F19F848B5A/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=1251894
Feb 21 05:28:11.206: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9AC7
        Channel ID i = 0xA9839D
                Exclusive, Channel 29
Feb 21 05:28:11.206: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x9AC7
Feb 21 05:28:11.206: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x9AC7
Feb 21 05:28:11.212: //1251894/50F19F848B5A/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Feb 21 05:28:11.212: //1251894/50F19F848B5A/CCAPI/ccCallModifyExtended:
   Nominator=0x234D0810, Params=0x234D12A8, Call Id=1251894
Feb 21 05:28:11.212: //1251895/50F19F848B5A/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x234D0CFC, Call Id=1251895
Feb 21 05:28:11.212: //1251894/50F19F848B5A/CCAPI/cc_api_call_modify_done:
Feb 21 05:28:11.212: //1251895/50F19F848B5A/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x224908D0, Call Id=1251895
Feb 21 05:28:11.262: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x1AC7mon
Hi Tulgabat,
I see what the issue is. Both the E1s are MGCP controlled and are registered to the CUCM. Dial-peers wont help on the gateway. You would need to ensure that you map the called number 99112234 to 2234 on CUCM itself. On the gateway config page for E1 0/0/0 (Call Routing Information - Inbound Calls --> , how many digits is it configured to receive, 4 or all? Are there any translation patterns that are configured and are getting matched? These are some things to look out for.
HTH.
Harmit.
Actually i tried to do it on Call Routing-> Translation Pattern->
  that first configuration, what else need to be done on CUCM?
Where can i check that receive digits number? at the moment i just need to forward one DID to one extension, do you have gmail chat?
Hi Tulgabat,
Go to Device --> Gateway --> Find this gateway in the list and select the endpoint E1 0/0/0 --> Scroll down and look for
Call Routing Information - Inbound Calls --> Significant Digits. What is it set to?
Harmit.
Hi Tulga,
HTH.
Harmit.
Harmit thank you for your support, it is working perfect.
Glad to hear that my friend, see you around! :-)
Harmit.
