CUCM IM & Presence Installation Issue
twstevensuk
Hi When Trying to Install CUCM IM and Presence i get the Attached Error
I have checked the Setting on CUCM and the server has been added
See Attached
Any Ideas?
5 Replies 5
Dan Lukes
This (misleading) error message may mean just "Security Password mismatch". See CSCur18862
Or it may be other issue described (with solution) here.
Try it and provide feedback.
Thanks,yeah i think it was the password i had to restart the installation and it worked
no we are seeing a different Issues
the Cisco Sync Agent is Running, if we start it it runs for a few hours and then fails
See Attached
Hi there
Again I bet you might be hitting a bug. This issue was there in CUCM 10. Try this below workaround
Change the CUCM server's default UI administrator password to a value which does not contain any of the following characters: ¬ ¦ £ € % ~ ?
Using the CUCM Admin UI:
Navigate to CUCM Admin UI > User Management > Application User
Select the default UI user
Update the password value
Click Save
Using the Admin CLI:
Execute command: utils reset_application_ui_administrator_password
Note: Changing the CUCM default UI password also changes the CUCM Instance Messaging and Presence server default UI password. It is necessary to manually update all configuration items which use the default UI password.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Thanks Ill give that a go but the only Special Character we are using is !
Change to a simple password and test it. If not please open a TAC. Thats your best bet
Hope this helps!
Cheers
Rath!
