CUCM LDAP Sync response - zero results
riedmueller
I am trying to re-create some labs from an CICD course, and I am having no luck accomplishing a syncronization between my CUCM node (10.5) and my Domain Controller (2008R2).
Running wireshark on the DC, the search message from CUCM nets a reply of "zero results".
LDAP System as sAMAccountname set up as the user ID
LDAP Directory is pretty generic
The server address at the bottom of the page is obviously correct...
The Windows Server is set up so that the user dirsync is a Domain Admin. The ou CCMUsers definitely exists and is populated with one user
The user has all the required fields filled out (I had Steve Vai playing in the background, so..)
I run Wireshark on the DC, filtered for traffic between CUCM and DC, and I see the search request, but also see a "zero results" message
Any help or insight would be greatly appreciated!
16 Replies 16
Hi all,
I am facing with the same issue.
I have CUCM 12.5 and CUCM get a result (0).
I tried to use CUCM 11.5 with the same configuration and CUCM succesfully import all users.
Any suggest?
austinwilly
 Hi all,
CUCM 12.5 close to the same issue but interestingly enough when i point directly at an LDAP server it works or if im using LDAP port 389 no TLS it works. I only experience the issue when I'm pointed at a VIP and using LDAPS with TLS enabled on port 636.
I could just add all of our LDAP servers in a big list for redundancy but then we really wouldn't have the load balancing that using a VIP on the NetScaler gives us so Ive got a TAC case open with Cisco to get some answers.
I should also mention that for us this only affects Authentication as far as we can tell. its still pulling a complete user list with information but when it tries to Auth a Users AD creds we have the issue.
