CUCM Recovery ISO
Rafael Jimenez
Level 4
Level 4
I need a CUCM recovery software version 6 BE... I know that is too old (EOS/ETC), but if its possible get this I will appreciate your help.
Thanks.
Jaime Valencia
You'd need to reach out to your SE/AM and see if they can get it for you
java
if this helps, please rate
Thanks Jaime,
one quick question, do you think the version 8.x recovery cd will work?.
I don't think it will work, they're version specific.
You're free to try it, but I have no idea what would happen.
java
