CUCM using media resource not sccp
Does anybody knows if it´s possible to register media resources on CUCM other than SCCP, like SIP for example?
Chris Deren
No, media resources use SCCP to register with CUCM. You can configure local registered transcoders to CUBE/router as they may be desired under some conditions:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115018-configure-cube-lti.html
Jaime Valencia
I believe you're asking PVDMx, if so, no, those are SCCP only.
EDIT: I see Chris already answered, this is what happens when you start replying and get sidetracked.
java
if this helps, please rate
Actually what I want to know is if is there any other kind of media resource, like an SBC MTF, can be registered on CUCM as media resource using for example SIP or H323 as protocol
MTF or MTP?
There are other device, i.e. video bridges, such as CMS, Conductor, MCU that register via SIP, but I am not aware of a transcoder or MTP to be able to do so and as far as I know only Cisco based MTPs and transcoders registered via SCCP are supported with CUCM.
