11-23-2010 10:18 PM - edited 03-19-2019 01:58 AM
We are running CUCM 7.1.3.10000-11 for a few months now and recently we encountered problems on our subscriber server.
Login to the web page https://x.x.x.x/ccmadmin cannot be displayed. Communication between publisher and subscriber is also unavailable via
11-23-2010 10:28 PM
What platform are you running? If you are running a MCS-7825-I4, MCS-7828-I4, or MCS-7816-I4 then you may be running into a nasty bug that has plagued some of us in the past months.
There is a community document and associated bug IDs here: https://supportforums.cisco.com/docs/DOC-12955
HTH.
Bill
Please rate helpful posts.
11-24-2010 01:32 AM
Hi William,
admin:show hardware
HW Platform : 7825I3
Processors : 1
Type : Family: Core 2
CPU Speed : 2130
Memory : 2048 MBytes
Object ID : 1.3.6.1.4.1.9.1.746
OS Version : UCOS 4.0.0.0-28
Serial Number : KQTFBTB
RAID Version :
RAID Firmware Version: 1.18.83.00
RAID BIOS Version: 6.0e.00.00
BIOS Information :
1.38
RAID Details :
LSI Logic IR Configuration Utility 2.00.15
Background command progress status for controller 0...
IR Volume 1
Volume ID : 5
Current operation : None
Volume status : Enabled
Volume state : Optimal
Physical disk I/Os : Not quiesc
11-24-2010 06:13 AM
Granted the generation of server is different but did you follow the document referenced and see if your hard drive firmware and model information matches those in the documented issue? It would be a prudent check.
In any case, what is happening is that the Linux kernal detected something wrong when writing to the disk. To protect data integrity, the OS flags a bit to make the disk read only. The issue could be a corrupted disk or a software (firmware, device driver) issue. I recommend you contact Tac if you are unsure how to proceed.
HTH.
Bill
08-31-2015 07:44 AM
Hi All,
We faced similar issue on CUCM and CUPS servers. Servers are running in VM.
CUCM: 8.6.2 & CUPS: 8.6.5.
Fixed the issue with Recovery file, It was temporary fix. To fix the file system errors, need to rebuild the servers.
Alagu
