CUCMBE r6.1(2) integration in redundant configuration with BE6K
dsmith.tig
If anyone has knowledge of the following please advise. Is it possible to utilize an existing CUCMBE r6.1(2) on MCS7825 platform in a redundant failover configuration with Cisco BE6K..? Cisco BE6K would be primary. Please advise
Thank you,
Doug
Jaime Valencia
No, the concept of 6K does not exist below CUCM version 8.
Before that, it's a one box, one point of failure solution, and all the redundancy you could get, is SRST. Right now, that is the 5K solution from the BE portfolio
What you're asking for, are for all matters, 2 separate clusters, so, no redundancy whatsoever between them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
