CUPC 7.0.2 get disconnected (unavailable) after a certain inactivity period
tka
The user gets disconnected/unavailable, (CUPC still registred with the callmanager) after inactivity period. He cannot anymore change his state. He has to quit and login again.
Any suggestions that may solve this prob !
Many thanks !
htluo
Level 9
Level 9
You may do a packet capture on the CUPC computer.  See if you got lots of "TCP checksum error"?
Michael
http://htluo.blogspot.com
There is no TCP Checksum error in the Capture .
Sorry for the stupid question.  Did the capture cover the time span that CUPC went from "Available" to "Offline"?
Michael
lpratt
Create a problem report from the CUPC client once the client goes dis
connected/unavailable to see why the subscribtion refresh is not occuring
for the CUPC user.  As mentioned there may be a connection issue from
CUPC with CUP.
Louis
