cupc 8.5.1 login fail
Hi All,
I have CUCM 8.0.3 cluster and installing CUPS 8.5.2 which I need to configure for Instant Messaging functionality only. As a client software the customer is planning to use CUPC, so I am testing CUPC 8.5.1 for him. I have installed CUPS and configured integration between CUCM and CUPS. Now I am trying to login to CUPC but can not do this - I receive back Login Fail message. I am definitly trying to contact CUPS because I can see in CUPS that the particular user is using CUPC as a client. I can also see that the username-password pair is verified - if I change the password to the incorrect one the error message changes to Invalid Username or Password. We do not use LDAP integration so the authentication is done against CUCM End-User credentials. I can login to CUPS ccmuser webpage all right with the creadentials, but can not login into CUPC. It looks like something is missing in the configuration but I can not work out what. Any advice will be gladly appreciated!
Thanks.
15 Replies 15
hi i do have an same issue how to change the host file??
