CUPC clear cached numbers
renemueller
Hello!
In CUPC, if you type in a number, CUPC will cache the number, so for the next time you type in the same number, it will show up automatically. Also wenn a call comes in, CUPC looks up for cached numbers and shows the match with maybe a name for the incoming call.
Is there a way to clear these "cached" numbers?
testeven
Hi Rene,
To delete all cache information of contact information from the client you need to remove these folders:
Windows XP:
C:\Documents and Settings\\Application Data\Cisco\Unified Communications\Client Services Framework
C:\Documents and Settings\\Local Settings\Application Data\Cisco\Unified Communications\Client Services Framework
Windows Vista:
C:\Users\\AppData\Local\Cisco\Unified Communications\Client Services Framework  - C:\Users\\AppData\Roaming\Cisco\Unified Communications\Client Services Framework
Windows 7:
Tere.
Please rate helpful posts.
Regards, Tere. If you find this post helpful, please rate! :)
