Bookmark
Subscribe
1047
CUPI API Issue following Connection 9.1(2) upgrade
MARIO POIER
Level 4
Level 4
Since upgrading Unity Connection from 9.1.(1) to 9.1(2) SU1 I can no longer establish a connection using the CUPI API.
The result code reported by the API is simply:
"Login failed to Connection server:unitypub.nait.ca"
I'm using the .NET CUPI Fast Start API version 3.0.28.0. In order to rule out my own app as the problem I've also attempted to use the CUPIFastStart project and receive the same result.
I've enabled VMREST micro traces on the publisher and collected the following from the Tomcat logs:
23:08:57.577 |12710,,,VMREST,3,DEBUG [http-bio-443-exec-3] com.cisco.connection.rest.SecurityFilter  - IMS result code: 0
23:08:57.578 |12710,,,VMREST,3,DEBUG [http-bio-443-exec-3] com.cisco.connection.rest.RequestFilter  - REQUEST GET version
23:08:57.578 |12710,,,VMREST,3,DEBUG [http-bio-443-exec-3] com.cisco.connection.rest.helper.DataHelper  - executeQuery: query='SELECT FIRST 1 Product FROM tbl_SchemaInformation WHERE IsCurrent=1'
23:08:57.579 |12710,,,VMREST,3,DEBUG [http-bio-443-exec-3] com.cisco.connection.rest.helper.DataHelper  - getValuesFromQuery: product=9.1.1.2TT1
23:08:57.579 |12710,,,VMREST,3,DEBUG [http-bio-443-exec-3] com.cisco.connection.rest.ResponseFilter  - RESPONSE filter IN
I interpret the first line of the debug to be a successful login attempt based on the information provided from http://docwiki.cisco.com/wiki/Cisco_Unity_Connection_APIs_--_Troubleshooting
From what I can tell this all seems normal. Fiddler also seems to indicate that the JSON response is being sent back to the client application.
JSON
     name=vmrest
     version=9.1.1.2TT1
MARIO POIER
Level 4
Level 4
As a further confirmation, I've stood up a new 9.1(0.32) version of Unity Connection and tested both the CUPIFastStart and my own code and it works just fine. Something has definitely changed in 9.1(2).
I also did some further debugging of the ConnectionServerRest API code and found that the WebCallResult for the GetVersionInfo function returned the following:
{    WebCallResults contents:
    URL Sent: https://unitypub:8443/vmrest/version
    Method Sent: GET
    Body Sent:
    Success returned: False
    Status returned 200:Ok
    Error Text: No version version returned logging into Connection server: unitypub, return text={"name":"vmrest","version":"9.1.1.2TT1"}
    Raw Response Text: {"name":"vmrest","version":"9.1.1.2TT1"}
    Total object count: 0
    Status description: OK
    ErrorText: "No version version returned logging into Connection server: unitypub, return text={\"name\":\"vmrest\",\"version\":\"9.1.1.2TT1\"}"
    JsonDictionary: Count = 2
    Method: "GET"
    Misc: null
    RequestBody: ""
    ResponseText: "{\"name\":\"vmrest\",\"version\":\"9.1.1.2TT1\"}"
    ReturnedObjectId: null
    StatusCode: 200
    StatusDescription: "OK"
    Success: false
    TotalObjectCount: 0
    Url: "https://unitypub:8443/vmrest/version"
    XmlElement: null
It seems odd that the StatusCode is 200 yet the Success is false.
I tried to post in the CUPI developer forums however the link is currently dead on https://developer.cisco.com/web/cuc/home
the first item here is why are you running 3.0.38 of the CUPI SDK?  That's from July of 2014.  the latest version out is 3.0.58.  It's easiest to juse use NuGet for keeping the libraries up to date (all my SDKs for notification, CUPI, ODBC etc... are available on NuGet).
Once you have that updated we can look at what's going on with your connection.
