Delay in dialing out
cisco
Hi ,
I am using CCM6.1 , i am able to dial out from my phones but there is delay of aorund 10-15secs before CCM dialout. Please tell me which setting i have to change so that i can decrease that delay time.
regards
Neo
cucm service parameters
java
if this helps, please rate
java
Jaime Valencia
you have interdigit timeout due to dial plan overlapping, you can modify T302 parameter or correct the dial plan to avoid this
java
java
Hi Java,
Please let me know from where i can modify T302 parameter.
regards
Neo
java
java
