Direct transfer calls
kavle
Level 3
Level 3
Hello Experts ,
could anyone help me what is major indication that we can check in the cisco CUBE SIP trace for the Direct transfer calls.
regrds,
kavle
M02@rt37
Hello @kavle
You can use VoIP Trace (Serviceability Framework) on your cisco CUBE to capture and analyze SIP messages, including those involved in Direct Transfer calls. VoIP Trace provides real-time debugging of SIP signaling, making it useful for identifying INVITE, REFER, Replaces, BYE, and 200 OK messages related to a transfer...
sources
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voip-trace-for-cube.html
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/sip/configuration/15-mt/sip-config-15-mt-book/voi-sip-call-transfer.html
Best regards
