Does CUSM 2.0.1 supports CUCM 6.1.2?
rgomes
I'm having trouble to add the CUCM 6.1.2 to the CUSM 2.0.1, I get failure on both the HTTP/S and CDR DB access.
I have doubled checked the entered credentials. I have set up successfully the CUSM as a billing server with the smuser account and it shows monitored on the CUOM 2.0.3 running on the same server.
The CUSM 2.0.1 Release Notes don't list 6.1 as a supported version.
Is there a way to debug this?
Thanks for any help
rgomes
I have tested on Lab and the CUSM 2.0.1 really supports CUCM 6.1.2. Now must debug the customer environment.
