Edith Unity Connection Messaging System USER
Guillermo_87
Hi Guys,
How I can edith the UnityConnection User?
My problem is when the voicemail is sent to email user, the recipient recibe with sender UnityConnection@mydomian.com
I need to change UnityConnection@mydomai.com to whatever@mydomain.com
2 Accepted Solutions
+5 indeed, I asked for the version, as this is now possible in 11.x as mentioned in the thread.
java
if this helps, please rate
That option is available in version 11. You will have to use the method Manish provides in the link I provided for anything else.
9 Replies 9
Jaime Valencia
What CUC version?
java
Hi Jaime,
Cuc  Version 10.5.2.12901-1
This has already been discussed:
https://supportforums.cisco.com/discussion/12586276/unified-messaging-email-change
java
Hola Jaime,
Entonces, la version de cuc que tengo no puedo editar esa configuracion?
NO, el thread es bastante claro en que esa opción es para 11.X, por eso es tan importante que no solamente pongas la pregunta, tienes que poner la versión, porque la respuesta puede variar dependiendo de eso. Por respeto a los demás miembros de la comunidad, sí quieres usar español, por favor postea en la comunidad en español, usa el drop-down de lenguage en la barra superior para ello.
java
The 'Manish' link doesn't seem to be available.
Can link to actual documentation be shared here, or even the steps to perform the account name change?
Hi BradEast1
I don't have this option in General configuration.
