Showing results forĀ
Search instead forĀ
Did you mean:Ā
expressway no RTP stream
ra 011
i have installed expressway core and edge 8.5 and jabber can register successfully from outside the network and signalling for calls is ok but there is no RTP stream .
what should i review to troubleshoot this issue and does i need any rich media license
Manish Gogna
You can find some good pointers in the following post, especially the firewall related comments
https://supportforums.cisco.com/discussion/12465356/mra-expressway-no-audio-jabber-calls
Manish
