External calls go right to Voicemail
Joe Della Valle
After switching user from 7945 to 7975 phone they can no longer recieve external calls. If someone calls them internal the call goes straight thru, but external calls go straight to voicemail?
We have compaired phone set up to a similar user and all is the same. No settings on the phone have been adjusted nor any CM changes were made.
Any thoughts?
Rob Huffman
Hi Joe,
If the user has a Softphone with the same exact DN that's working properly, then
the steps I listed would not be required. The only thing I can think of at this point
is that the Partition/CSS on the 7975 must be different what than the Softphone
or the old 7945 were using
I have had to remove things completely before to clear an issue but it doesn't
seem like this would be necessary in this situation.
Cheers!
Rob
7 Replies 7
Rob Huffman
Hi Joe,
A couple of things to try here
Let's say the DN in question is 5522, make sure you have removed the old
7945 completely, then change 5522 on the 7975 to something else temporarily
let's say 2233, then go to Call Routing > Route Plan Report > Unassigned DN's and
remove 5522.  Then reset up 5522 on the 7975 and retest
Cheers!
Rob
We deleted the old phone from CM. As far as giving the new phone another DN, if we give the phone a new number then remove the old number, are we deleteding the number from CM? If so, will we have to readd the number back to CM?
I'm not sure how to add a number back to CM, is that an easy process?
Rob Huffman
Hi Joe,
Once it's been completely been removed via the process I linked you can just
go right back to the 7975 and replace the "temporary" number on the DN config page
with the old "permanent" number/DN
You will have to re-do the forwarding and name display etc. but it's quite straightforward
Cheers!
Rob
Until a DN has been removed via the Call Routing > Route Plan Report > Unassigned DN
method, it still holds some remnant info in the database which can cause these weird
issues.
Rob,
As test, the user also has a soft-phone enabled on the system. So, we opened the soft-phone and tested calls from outside and they go thru fine. This phone uses the same extension as the hard-phone.
So using the method above for removing the number from the DB, will this still be a fix methodology being it works fine on the soft-phone?
Our other thought would be to remove the user's account completely from CM and re-add them back?
Thoughts on both?
Rob Huffman
Hi Joe,
Cheers!
Rob
Well you hit it, but I was able to discover the discrepancy just before you sent this...
When I looked at both hard and sof phones I noticed they were set to different Partitions. Once set to the same, it worked fine.
What a bugger of a fix to fine........ right in front of my face.....
Rob Huffman
Hi Joe,
Nice work my friend!
Sometimes it's very hard to spot these things as our eyes see what they
want to see I like to get one of my co-workers to look at configs just to
get a different perspective.
Cheers!
Rob
