Faxing to voicemail in Unity or Unity Connection
Michael Murray
Level 2
Level 2
Does Unity or Unity Connection have the capability for callers to send faxes to the users voicemail box? Or do I need something like Cisco Fax Server to do this?
-mike
David Hailey
For Unity, there is a built-in tool that can be used for limited faxing capabilities (less than 50 users, it's called Fax Util).  Outside of that, you can integrate with any number of Fax Servers.  Unity Connection only supports integration with Cisco Fax Server (aka, OpenText Right Fax) for faxing capabilities.
Hailey
Please rate helpful posts!
David Hailey
Hailey
Dave,
Thanks for the quick response!
-mike
