Forwarding a DN
    Rob, could I have a little more gidence in the CTI Route point for my DN. maybe a step by step
Thanks Charlie B
Rob Huffman
Hi Charlie,
No worries
Let's say that the user's old number was 6345 and the new number is
7777.
1. Find the 6345 phone in CUCM via Device>Phone>search>DN 6345
2. change the DN page in CUCM via Device>Phone>6345 device>DN config
   to 7777
3. go to Call Routing>Route Plan Report>Unused DN's>find and delete DN 6345
4. go Device>CTI-RP>Add new> configure 1st page with appropriate CSS etc>Save
5. at bottom of page you will see "add a DN">add 6345>set callForward All to 7777
    with proper CSS
6. save
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Hi Rob
Well described, but i have a question - out of intrest why do you need to user CTI RP to enable call Frwd from one number to an other one...rather enable CFWA on the DN page...?
Kind Regards
Pramoth
Hi Pramoth,
Good question
The reason we are using a CTI-RP is that Charlie was looking for
a "virtual" solution as the physical phone was to be re-assigned.
https://supportforums.cisco.com/thread/2173111?tstart=0
I did offer up the DN page option in my first response but also noted
that I prefer the CTI-RP method. DN's that float around without being
able to be easily referenced tend to either disappear or be lost and
forgotten which isn't great when we are paying for DID/DDI numbers
Cheers!
Rob
Hi Rob
Thanks for the explaination ..make much sense...
Kind Regards
Pramoth
