Headset Issues with APC-42 cable & SAVI 740 series headset with CP-7900 series
lalockrid
While using the headset the user can hear the call coming thru the handset
Rob Huffman
Hi there,
Please check out this bug/enhancement;
Audio on Handset and Headset for Guinness phones
CSCsj60872
Symptom:
If you listen closely, the phone will play the audio to headset and handset simultaneously
at all times.
Conditions:
It happens on all 79XX phones until firmware 8.3(5)
Workaround:
This is a product specific configuration now available under CCMAdmin > Device > Phone for 79X2 and 79X5 phones.
Handset/Headset Monitor:
When handset/headset monitoring is enabled, a supervisor can pick up the inactive handset/headset and hear the call in progress. For example, if an agent is on a call on the headset, a supervisor can hear the other party on the handset. Only the microphone on the active handset/headset is in use. For example, if an agent is active on the headset, then the headset microphone is active and the handset microphone is disabled.
thanks that explains, why it is happening and how to change it.
