help in uccx (leave audio recording file for caller)
yaser.nss
on the attached snapshot for scripting "leave recording audio for caller" when the agent out of office, it's work successfully but when second call comes over in this case the same file is recorded, so how can i make it to record as
recording1.wav
recording2.wav
recording3.wav
You can use a 'set exception' step to set a ContactInactiveException trigger to go to a Label.
Do this before the 'recording' step - if the caller then hangs up, it will go to the Label that should be placed so that the steps to upload the recording are completed.
Currently the script will just stop if the caller hangs up.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
It looks a lot like you are trying to imitate a voicemail system.
I would suggest that you create a voicemail box, and redirect the caller to that - this will manage your recordings and allow the person who needs to pick up those recordings to access them easily.
Aaron
Hi Aaron
Many Thanks for reply,
i tried scripting that and after deep digging, i did it as show on the attached ///// but am facing one more problem that's recording duration if it's not end the file will not be generated, i really appreciate your help in order to make it generate once the end user end the call.
Aaron
Hi Aaron,
i really appreciate your kind support it's work very well.
Many Thanks
