Help: Notification Message (with No WAV File) to my Corp SMTP address.
Hi all,
I a having problems to send notification messages to my email address, but without the wav file, is that supported?
When I go to edit --> message actions --> email : I select "Accept and Relay",
but I don't want the wav file, then I disable that.
And unity does not send me anything.
Could you please help me to see where can I enable that option?
Unity Con 10
Thank you.
Juan.
Jaime Valencia
Under notification devices, use the SMTP option.
java
if this helps, please rate
Well, thank you for letting me know is in there.
I disabled accept and relay the message in " edit --> message actions --> email"
and I went to Notification Devices --> SNMP
I added all the corresponding fields.
Besides of that... Jaime, do you think about in any other restrictions that could be happening? We know the smart host works, because I can receive the .wav files.
Thank you very much.
Juan.
