*Hep* Disaster Recovery System get stuck
Ing.Alejandra
Beginner
Beginner
Hi All,
Hope you're fine. I'm trying make do a CUCM Backup , but I can´t start, I click : Backup> Backup Device and it gets stuck... I also tried to click any diffferent option but is the same behavior... I also keep monitoring cucm cpu and  it not increases.
Any ideas ? how can i fix it ? :(
CUCM Version : 10.5.2
Thanks!
I attach an image.
2 Accepted Solutions
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Try to restart the DRS services on your server and then try again.
java
if this helps, please rate
Jaime Valencia
No, the DRS services are only used for backup and restore.
java
5 Replies 5
Jaime Valencia
java
thanks a lot Jaime !
Restarting those services , cause any service impact?
Regards!
Jaime Valencia
java
Hello Jaime,
I usually restart DRS services in case the Disaster recovery page got stuck but right now I am trying to do a backup I have a CUCM 12.5 when I restart the DRS services the page it is still stuck I cannot access any feature in Disaster recovery system I also tried below steps described but it is the same :
https://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/117545-technote-unity-00.html
Can you please let me know if there is any solution for this?
Well from what I have been searching online didn't find anything else
Tanios
Anas Hafez
Beginner
Beginner
You can also try to regenerate tomcat-ECDSA certificate if expired, CUCM 14.0.1
Recognize Your Peers
