How bind media|control source-interface command modify the SDP ?
david.alfaro1
Hello Dears,
I know that the bind media|control source-interface command influences in the source of a SIP request whether the network is routing the same interface or another one. So, signaling/control and media binding are used to change the source IP address information in layer 3 packets and of course Layer 7 SIP headers specially in the SIP SDP message body.
In order of the above, when this command handles a SIP request SDP header, I am wondering to know, to handle the source IP address, specifically what SIP request SDP field is handled, is the o= field or the c= field, or both?
The documentation just say that the command handle the source IP address in the SIP request, but it does not specify which SIP request SDP field o fields (c= or o= or both) the bind command handle the source IP address in, or if the one of these fields (maybe the o=) remains equal as the routing cef table or it is modified too by the bind command, or both of them (o= or/and c=).
Kind regards,
Purely speculative but instinctively I would say that it affects all of these fields in the SDP. However to be absolutely sure I would recommend you to do your own verification on this by setting different interfaces for the bind statements and capture the output from debug ccsip message for each test call.
Response Signature
