How do I interface with CUCDM
I am developer who is trying to connect to CUCDM from my application. I would like to perform actions like Create User or Phone or line etc on CUCDM via java code.
Do you know where I can find the details on how to do it ? Some link or developer cook book.
I have interfaced before to CUCM using CISCO AXL (https://developer.cisco.com/site/axl/) . I was looking for some thing similar that tells me how do I connect and perform the transactions.
Simon Coventry
If you are trying to add a cluster to CUCDM I think you need to add a customer by navigating to 'Customer Management > Customers > Add'
You'll need to have SNMP confiugred in CUCM before this will work and you may need to have an instance of prime collaboration running as well...
Good Luck
