How to browse to CUE front end
nac
I am wanting to browse to the CUE admin page. I have the address of the router it sits on, can anyone tell me how i browse to the CUE admin? Is there a directory i need to specify?
Thanks!
jguggehe
Good morning.
You should be able to access the GUI by opening your browser and entering http://a.b.c.d/Web, where a.b.c.d is the IP address of the module.
I hope this helps! If you found this post helpful, please rate it.
John
hello,
You need to give the sevice engine's ip.Not the service modules ip.
like in sh ip int brief u get the module ip say-192.168.1.1
your cue exp ip add may be 192.168.1.2
just enter 192.168.1.2/web
