How to change SIP signaling port for 5 servers
dshumake
Level 4
Level 4
I have a server group with 5 servers for one of the dial-peers I have on the cube. I need to set up the connection to use port 5062 for one of my dial-peer.  All my other SIP connection is using the standard port 5061.
is there a good configuration I can used on the ISR cubes.
dshumake
Level 4
Level 4
ok I found the solution..
voice class server-group 3002
ipv4 40.x.x.x port 5062
dshumake
Level 4
Level 4
I also found that you need create the tenant and add
listen-port secure 5062
