03-02-2025 06:35 PM
I have a server group with 5 servers for one of the dial-peers I have on the cube. I need to set up the connection to use port 5062 for one of my dial-peer. All my other SIP connection is using the standard port 5061.
is there a good configuration I can used on the ISR cubes.
Solved! Go to Solution.
03-02-2025 06:58 PM
ok I found the solution..
voice class server-group 3002
ipv4 40.x.x.x port 5062
03-02-2025 06:58 PM
04-24-2025 05:01 AM
I also found that you need create the tenant and add
listen-port secure 5062
