How to correct error when running DAD tool ?
jeman85
When I run the DAD tool on a Unity 3.1.3 box
it gives me an error that I should log in as the Directory Service account although I already did.
( accounts AvDSAD and AvDSGlobalCatalog services are running as)
This is really puzzling. Has anyone experienced this problem? Hod do you fix this? Please advise
Best regards,
jeman85
7 Replies 7
lindborg
Which version of the Directory Access Diagnostic tool are you using?
I installed and used the DAD for 3.x Unity servers from the ciscounitytools.com ( Answer Monkey ) .
Really looking for the version number here... please look in the About box and get me the full version number string. I've released probably 20 versions of that on CiscoUnityTools.com (AnserMonkey.net).
Sorry for the late response.
The version of DAD we used is 1.2.0.9 . Hope this helps .
Thanks.
I am running DAD 1.2.0.9 on UNity 4.0.4SR1 with the same problem.
Did you ever find a solution?
- Ken
- Ken
Jeff,
I am having a similar issue with DAD version 1.2.0.11 on Unity 4.2. Any time I try and run the Mailstore Access Tests it asks for the password for the Mailstore service account and then promptly rejects the password. I've even reset the password for the account in the AD, and in the services to ensure they match. Yet DAD tells me the password does not appear to be correct. Thoughts?
Lee
