How to do Call Foward All for a Hunt Pilot without Web Interface
ocarmona777
Hello we have CM 4.2 and we have a hunt pilot for the 2 receptionists.
I believe there MUST be a way, either by scripting or a workaround to setup a button to Call Foward All a Hunt Pilot - I will like to do this without depending on the computer to use the Web interface to do it.
Anybody think is possible?
pklos
Level 4
Level 4
You can change it directly in CCM SQL database.
That would still be PC Dependant. Is there a way that maybe through a "service" on the actual phone or a button that they can easily press.
Yes, you can create XML service linked to speed dial button (but it only User Interface). so asp/php/??? script generating this service can change Forward All parameter for hunt pilot using SQL Query or AXL API.
regards,
pk
