how to replacement certificates in CUCM for management
carl_townshend
Hi All
Can anyone tell me how to replace the certificates in Call manager used for the management and user web pages?
Many thanks
Carl
Mike_Brezicky
The certificates used are the tomcat certs. Are you trying to regenerate self signed or use your own CA based cert? If the latter is true, then you will need to generate the CSR from the OS admin page to create the cert request for your CA.
Anurag Srivastava1
Please refer the below link may be helpful...
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html
Thanks.
Please rate if it is helpful and mark as accepted solution if applicable..
Please rate if it is helpful and mark as accepted solution if applicable....
