Hunt Pilot appear in Coprporate directory
hassan.fahmy
Dear All,
i have a hunt group with hunt pilot --> DID number, can i add this number to users list to appear in phone corporate directory numbers ?
2 Accepted Solutions
Chris Deren
Sure, all you have to do is create End User with telephone number field set to this number under end users if you are using local user directory or add a user to Active Directory if you are synched with LDAP.
HTH,
Chris
In my opinion it does not make sense to add/delete single user with BAT as it is very easy and trivial to do this via the GUI, simply go go User Management --> End Users and locate the users there for editing/deletion or click Add New button to add a new user.
HTH, please rate all useful posts!
Chris
Chris Deren
HTH,
Chris
Dear Chris,
Thanks for your fast response, but can i ask you how can i add/delete a user ? i know it kind of late to ask this kind of questions, but
  • Till now i add users using bulk administration tool as i have a txt file has all uses, each time i add a new user i just add to this txt file a user name with the new DN after upload the file and insert users with that file.
  • when i want to delete a user i go to BAT and query delete user
how can i manage add user or delete user in the proper way
realy thanks for your help
Chris
Dear Chris
Thanks for all your posts and useful info.
