09-13-2013 01:51 AM - edited 03-19-2019 07:16 AM
Hello
The normal extensions seem ok but the hunt pilots seem to stop ringing after 4 rings. I have checked the 'Forward Hunt No Answer' settings and these do not seem to be configured. It seems to happen on every hunt pilot so I am wondering if its a global setting?
Solved! Go to Solution.
09-13-2013 05:33 AM
Hi there,
Have you checked the RNA Reversion Timer on the Line Groups
along with the Maximum Hunt timer on the Hunt Pilot itself ?
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
09-13-2013 05:33 AM
Hi there,
Cheers!
Rob
- Bob Marley
09-13-2013 06:59 AM
Hi Rob
Thanks for the reply, I have set the Maximum Hunt Timer on the Hunt Pilot to 300 (seconds) but this made little difference.
I will read up on the RNA Reversion Timer and see if this could be having an impact.
09-14-2013 06:55 AM
It was the RNA Reversion Timer so thanks for your help Rob!
Changed this to 30 seconds and the hunt pilots ring for longer now
