I have a CUE 2.3.4 When I load a Single digit menu script I get a warning
mstewart
HELP
I have a script that I created to use a single digit menu, but the CUE Auto Attendant gives me a warning when I attempt to configure the Auto Attendant.
My client just want the following options.
For the Branch Mgr press 1
For the Asst Branch Mgr press 2
To leave a general message press 0 or stay on the line.
I have attached the script.
6 Replies 6
Markus Schneider
What is the warning you get and at what point do you get it? Often, this is caused by not having a subflow that you're calling on the card, such as dialbyname.aef. If that script isn't there, then you'll get a warning for sure. But there's lots of other conditions, so it'd be important to get the exact message.
I was able to modify the script and test it and it works correctly now.
Thanks for the response.
howct7231
Hi stewart,
Can I have a glance on your script ? I am in the verge of coming out a script for my company, may need to explore how your cue auto attendant, hope I can have the privilage for that.
Attached is acopy of the script I built.
Thanks for replying.
I have problem on viewing your script when log in anoymous to the crs editor. Is there any way of viewing your script ?
Appreciate
You will need to down load the Cisco CUE Editor to modify or view the script.
