I need to designate CUCM-2 as Subscriber
Ibrahim Jamil
Level 6
Level 6
Hi Guys
i have 2 Independent CUCM
CUCM-1 192.168.100.100
CUCM-2 192.168.100.101
I need to designate CUCM-2 as Subscriber , what i have done is on CUCM-1 , i have added CUCM-2 as Subscriber but still dont show up as Pub/sub
what steps i missed
what should i do to accomplish such setip
thanks all
5 Replies 5
Anthony Holloway
Can you paste the output of utils service list from CUCM-2?
Hi Anthony
which service on CUCM-2 must be started in order to let CUCM-2 shows as sub in CUCM-1
here you go
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Name Service Cache [STARTED]
Entropy Monitoring Daemon [STARTED]
Cisco SCSI Watchdog [STARTED]
Service Manager [STARTED]
HTTPS Configuration Download [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco AXL Web Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco CAR DB[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CTIManager[STARTED]
Cisco CallManager[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco Change Credential Application[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco DirSync[STARTED]
Cisco E911[STARTED]
Cisco Extension Mobility Application[STARTED]
Cisco IP Voice Media Streaming App[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco Management Agent Service[STARTED]
Cisco Push Notification Service[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco SOAP - CallRecord Service[STARTED]
Cisco Smart License Manager[STARTED]
Cisco Syslog Agent[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Cisco Trust Verification Service[STARTED]
Cisco User Data Services[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Platform Administrative Web Service[STARTED]
SNMP Master Agent[STARTED]
SOAP - Diagnostic Portal Database Service[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco Bulk Provisioning Service[STOPPED]  Service Not Activated
Cisco CAR Web Service[STOPPED]  Service Not Activated
Cisco CTL Provider[STOPPED]  Service Not Activated
Cisco CallManager SNMP Service[STOPPED]  Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED]  Service Not Activated
Cisco DHCP Monitor Service[STOPPED]  Service Not Activated
Cisco Dialed Number Analyzer[STOPPED]  Service Not Activated
Cisco Dialed Number Analyzer Server[STOPPED]  Service Not Activated
Cisco Directory Number Alias Lookup[STOPPED]  Service Not Activated
Cisco Directory Number Alias Sync[STOPPED]  Service Not Activated
Cisco Extended Functions[STOPPED]  Service Not Activated
Cisco Extension Mobility[STOPPED]  Service Not Activated
Cisco IP Manager Assistant[STOPPED]  Service Not Activated
Cisco Intercluster Lookup Service[STOPPED]  Service Not Activated
Cisco Location Bandwidth Manager[STOPPED]  Service Not Activated
Cisco SOAP - CDRonDemand Service[STOPPED]  Service Not Activated
Cisco Serviceability Reporter[STOPPED]  Service Not Activated
Cisco TAPS Service[STOPPED]  Service Not Activated
Cisco UXL Web Service[STOPPED]  Service Not Activated
Cisco Unified Mobile Voice Access Service[STOPPED]  Service Not Activated
Cisco WebDialer Web Service[STOPPED]  Service Not Activated
Cisco Wireless Controller Synchronization Service[STOPPED]  Service Not Activated
Self Provisioning IVR[STOPPED]  Service Not Activated
Primary Node =true
thanks
You see how it says "Primary Node =true" at the bottom? That means you cannot use this server as a sub. You will need to rebuild it from scratch, and during the installation when it asks you if this is the first node in the cluster, you say No, and then you proceed with the installation from there. I recommend you have the install guide handy during that time.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/11_0_1/CUCM_BK_IDF93684_00_installing-cucm_1101/Installation_tasks.html#CUCM_TK_S2EB5F8C_00
TONY SMITH
Do you mean that CUCM-2 was already built as a standalone publisher?  If so then you need to reinstall from scratch and answer "No" to the question "is this the first node".
thanks guys
