IM and Presence active partition usage is 100%
sean.wellington
I am currently working on a CUCM cluster with a single publisher, subscriber and IM and Presence server.
The IM and Presence server is currently showing an active partition usage of 100% in RTMT.  My question is: What are the best ways to reduce this disk usage on the IM and Presence node's active partition?
If it helps, the versions are as follows:
CUCM cluster: 11.0.1.20000-2
IM and Presence: 11.0.1.10000-6
Manish Gogna
Hi Sean,
One of the options is to boot from recovery ISO and delete the rolling logs (  ma-log4cpp_rolling.log ) , however it is recommended to do it with TAC assistance. Sometimes even this does not work and a rebuild might be required.
Manish
- Do rate helpful posts -
